Hydraulic Spool Valve Levers Sticking
JBASport
I have an old access platform and 2 of the Spool levers are stiff and won't return to the neutral position like the others. Is there a way of freeing then without having to drain the hydraulic fluid? Any help would be much appreciated.
jd6820
jd6820
Slacken end caps off and see if they are full of water or oil that could be causing resistance. Also you should find a centralising spring that brings the valve back to neutral, check its condition.
JBASport
Thanks. Will fluid leak out if I take off the end caps?
could try eyeballing the pivots under the rubber boots and see if they're free enough/seized ?? :unsure:
Yeah give any linkages abit of lube! My telehandler had gone tight after been parked up for 8 months. Some ACF50 in the right places and it was good as new again 👍🏼
JBASport
Just a follow up. I have taken the caps off the end and as you suggested, water ingress was the issue. I took the 2 offending levers off, cleaned them and greased them and all is working well now. Thanks again for your help. This is a great forum with so many willing and helpful people like yourselves.
