How to Drain tank of Peljob 5ton excavator 1997
Mick-the-fitter It’s what I do! Sep 3, 2023 #5 I though they had a drain bung underneath! 22mm or 27mm
V8Druid do it as well as you can,but learn to do it better Sep 3, 2023 #6 Thomas7740 said: What tank would be a big help? Click to expand... PMSL
V8Druid do it as well as you can,but learn to do it better Sep 3, 2023 #7 Brendan said: Vacuum extractor, or take an outlet pipe off Click to expand... probably on a dip tube
Giles Well-known member Sep 6, 2023 #8 I had to drain fuel tank on js130 fuel Line doesn’t work as on an upstand, I bought a cheap wet/dry vac for £40 and used that. Taped a piece of 33mm waste pipe to it to get into all corners etc
