Will_c
Hi all,
I’m currently in my final year studying Agricultural Engineering at Harper Adams University, and for my honours project I’m looking to design and build a homemade tiltrotator to suit a Bobcat E27z excavator.
The machine is owned and used by my father for construction work and occasional landscaping. In the past we’ve had quotes from the major tiltrotator manufacturers, but the cost is difficult to justify — in most cases around a third of the machine’s value, which is hard to stomach when a 1-ton machine can be bought for similar money.
Rather than switching to an S-type coupler, I’m planning to retain the existing coupler style, as we already have multiple buckets and attachments to suit it.
Photos or videos of other home-built tiltrotators would also be great — I’ve only managed to find a handful of DIY examples online so far.
I have access to the university workshop facilities to build the attachment, although I intend to complete the majority of the work at home using fairly basic tools, as I’ve seen others do.
I will do my best to document the process of the build and post some photos and videos along the way
Thanks in advance — all input is welcome.
Cheers Will
Current design thoughts
My intention is to build the tiltrotator using:- A standard-size slew ring
- Either tilt cylinders or a helical actuator for the tilt function
(although helical actuators seem very difficult to source and prohibitively expensive) - A second-hand hydraulic coupler for the hitch
- Plasma/laser cut parts welded together for the Frame
Design constraints
Some of the main constraints I’m working with are:- As low a build height as possible
- The excavator is fitted with a Geith hydraulic quick coupler
- The factory-fitted hydraulic thumb needs to be retained, as it’s extremely useful — removing the cylinder and hydraulics each time would be impractical
- Designed to be either direct-mounted or mounted under the coupler
- Six-pipe hydraulic design using the factory-fitted auxiliary lines
(a diverter valve is fitted to the thumb so it can be switched over to the aux supply)
What I’m looking for
If anyone here has experience with:- Designing or building a DIY tiltrotator
- Using slew drives / worm drives (IMO or equivalent)
- Sourcing compact rotary unions or alternative solutions
Cheers Will
