Hiab Trailer micro
Here is a unique opportunity to purchase a ready made towable hiab trailer. When I bought this in 2019 it has a Fassi unit fitted which I have moved onto a different trailer.
Trailer weighs over 1000kg as it is and weighed about 1700kg with the crane and batteries. I’ve got all the original drawings from when it was built in 2006 by a fabricator in south east. Originally built to install lighting poles on playing fields.
Space for 24 lorry batteries and will be adaptable for any small hiab unit. Would cost £2-3K to build and would probably cost half of that in just the components and materials even if you built yourself.
Wheels will slide in for narrow access (like a nifty lift) although currently seized so needs greasing.
Looking for £1500. Based in EX22 (Devon Cornwall border
Or offers!!!
Or offers!!!
what breed is the running gear on that?
must have some nose weight with a crane installed on it .... must be heavy enough as it is if it weighs a tonne bare :oops:
Probably less than 1000kg thinking about it, but not run across the weigh bridge. The Fassi unit uses to weigh 550kg plus a couple big batteries and the whole thing would have been about 1500-1800kg. It’s all in the design notes somewhere from the chap that built it. Nose weight was always perfect, well balanced but still a heavy little trailer for single axles In my opinion, prefer it on the tandem that it’s built onto now.
Running gear is 1.8 ton indespension units and the tow bar nothing special- avonride?
