A
Al_1977
Evening all,
Need some advise pls, this looks like a right nightmare.
I wanted to get the old beast out to do a bit of graft this morning, she's not been started for a while so with a fully charged battery, turned the ignition to pre-heat for approx. 25seconds - then tried to crank her, I heard the starter motor engage; but no cranking. When I tried turning the key again, I could hear a relay (or something) activating behind the side-dash, but no main dash (pre-ignition) warning light, no starter motor engage.
First port of call was the fuses on the battery terminal, which all buzzed out for continuity on the multimeter... then checked the blade fuses in the side dash, no issues there.
As all appeared to die after the pre-warm, we were drawn back to the battery box to double check that fuse block... and when the terminal was removed - all became clear. There was no heat in the plastic so this was the startup that was obviously the final straw of something that had been brewing since before I bought it (this was the first time I'd taken the battery off to charge it).
It's a 1999 project 12... thoughts on best way to repair?
