Gas burner question
@Stroppymonkey @pettsy any ideas
Bought this for hot jointing asphalt as trust aren’t keen on surfacing lads heating watering cans in a burning pallet fire in half a drum!
That’s my 80 year old dad who’s taken it on himself to fix it it seems haha
Thermocouple either faulty (looks new?) or not getting a good heat signal, or got a bad connection or the coil in the gas valve weak. The flame playing on the thermocouple looks pretty weak, likely a blocked jet or air port on that. Try using a blow lamp gently on to the tip of the thermocouple to see if it holds without the button being pressed.
Got to yard this am regulator was turned down, turned it up and away it went from .5 bar to 2.5 bar burning much better and staying lit lol dad was bit sheepish lol 😂
Rob65
Gilles, I’ve got a basic bitumen melting pot that’s looking for a new home. It’s yours want it.
It’s had very little use and the burner is in good condition. It doesn’t have any temp controls or any technical bits do go wrong.
PS - No I haven’t forgotten about your wacker throttle. It still on the list of things to do. Work has been mental this last few months.
Thank you rob I have a basic pot boiler as well but you need to ladle it out so it’s more problematic than this one with the side tap and looks a bit less professional which is half the battle with the box tickers
Sweet yeah that’d be good to get it sorted and still Have that imer mixer if going as well 👌
