Is it possible to get a pair of 50mm bucket pins drilled for grease ways and a groove carved out of pin faces to allow grease to move along the pin and then the pin end countersunk and threaded for a grease nipple ?
Cheers Smiffy at least I know now it can be done .For the most part very easy to drill the duct and tap it. The hard part is making the groove helical to properly grease the pin.
Can be done with a mill and a dividing head but will be shakey. Or if someone has a CNC machine then easy. My dad made a piece of kit to mount on a conventional lathe for doing for doing helical grease paths
I’ve never seen a pin done like this. Only bushes. I’d assume Vins bushes already have helical greaseways if OEM spec.For the most part very easy to drill the duct and tap it. The hard part is making the groove helical to properly grease the pin.
Any small engineering shop will be able to drill, counterbore and tap a grease way in a pin.
Should just push out regardless. No matter what the groove in the bushes will only line up with the grease hole at one particular point of articulation. And I can't recall a machine ever specifying at which angle you grease everythingIt’s on one of the other hitachi pins in the machine .
I thought I’d seen it on bucket pins in the past but maybe I’m mistaken .
If I didn’t do the grooves along the pin surface would the grease holes across the diameter need to be in line with the bushes or would the grease push out around the bushes if the holes were in the centre of the pin filling the void between the bushes
So a hole across the centre of the diameter of the pin should do the job , then the grease will push through the bosses ?Should just push out regardless. No matter what the groove in the bushes will only line up with the grease hole at one particular point of articulation. And I can't recall a machine ever specifying at which angle you grease everything
Why is it necessary to grease it via the pin? Can the joint not be greased via the bosses? I know pin end greasing is convenient but it does weaken the pin.
It’s not the hole through the middle that weakens it, it’s the cross drilling.Not necessarily. A hollow pin can potentially be stronger than solid. Although I don't know the maths of pin size and wall thickness v shear force and bending moment
I was about to say that. Just follow a wrap of tape or something to keep it neat.If you think about it, a helical groove doesn't need to be precision machined.
Nothing in the groove will be in contact with anything (other than grease), so there is no reason you shouldn't cut the groove with an angle grinder.
A lot of OEM pins are cross drilled. Does weaken them at all as the shear forces don’t line up with the cross drilling.It’s not the hole through the middle that weakens it, it’s the cross drilling.
my little Fleming walker used to kill the boom to dipper pin regularly on the grease hole .. but was a 5mm hole in a 25mm pin ... (last one I broke digging a ditch along the field beside the driveway here - keep the water at bay and in the field 'til I let it out where I wanted it) ... reduced the hole to 3mm and it lasted for the remaining 3/4 of the length and a few other scrats with it since ... was a PITA ... rest are the same through drilled, but never gave troubleI’ve had pins break through the cross drilling in the past, OE pins. I’ve also got lots of things with pin end greasing that are fine. In my opinion a cross drilled pin in the wrong position has the potential for failure. Many areas will be fine, but a few places I’d rather not have cross drilled pins, bucket pins are probably one of them. But that’s only my opinion.
