crawler tractor with bulldozer dozer views
crawler tractor with bulldozer dozer views:
I went to an agricultural machinery dealer, on display there are a Trekker tracked landini, and a McCormick, which one would you choose by equipping them with a bulldozzer blade? which of the 2, which of the trekker series or which of the mccormick? or if you do not consider them valid on which brand and model would you orient yourself with the characteristics similar to the 2 models mentioned above? thanks let me know, comparing them which is the best and most reliable ??
Trattore Landini Trekker 100 montagna con apripista combinata solo versoio-sgancio rapido-Motore Perkins 4 cilindri - suola da 450 mm.-carro ottimo-inversore- Telaio 4 montanti
