Looking out for a conveyor around 4m ish. Single phase 110 would be ideal like the Shifta. Southwest end of country !
How new does it need to be?Looking out for a conveyor around 4m ish. Single phase 110 would be ideal like the Shifta. Southwest end of country !
It’s for playing with to see if it works with screener . Customers wont see itHow new does it need to be?
I'd just hire to test it. You can try different lengths etc.It’s for playing with to see if it works with screener . Customers wont see it
I''ve a old one in the yard, about 5m that i've used several times to shift muck out of tight spots. It's going in the bin soon as the man that put a deposit on it in 2019 hasn't appeared again. I'll take some photos. Motor on it has burned out from memory but it was only a 230V thing we ran off a Gen set.It’s for playing with to see if it works with screener . Customers wont see it
Could be interesting… whereabouts are you in Narnia?I''ve an old one in the yard, about 5m that i've used several times to shift muck out of tight spots. It's going in the bin soon as the man that put a deposit on it in 2019 hasn't appeared again. I'll take some photos. Motor on it has burned out from memory but it was only a 230V thing we ran off a Gen set.
That’s sounds far too sensible !I'd just hire to test it. You can try different lengths etc.
That’s sounds far too sensibleI'd just hire to test it. You can try different lengths etc.
Cheers guys. I think a 4m one would be AOK. Will start keeping more of an eye on exeter auctions.... Nothing else is remotely accessible for me really.I’ve got 3 small 3m ones which you can just about lift on your own if you’ve had your wheatabix so the big ones are machine or multiple lift
