Container doors needing TLC
I’ve had this container for about 20 years . It’s spent the last 10 in a rented steading with the left door permanently shut and the right permanently open .
It’s now going to sit outside in my wee yard at home so the doors need to operate properly. The 2 long rods that turn to lock the doors are seized solid . I’ve sprayed them with deblock but not shifting .
They bolt on . What’s the best way to sort them ?
Can you buy replacement ones ?
Also anyone fitted a personnel door in the side of a container ?
I’d like to put one in it .
Any ideas ???
Any ideas ???
If you can unbolt them I would have thought you could get them freed off the are not the most complicated of things
Even if you only get one working to pull the water seal tight then fit a sliding bar across the front for security
Some round here was selling kits for containers consisting of a giant bolt made of 6 inch square box so a petrol disk cutter couldn't easily cut through the whole thing then channel to weld on the inside of the door one piece on the door and one piece on the container wall so as the doors closed the pieces locked together so if the hinges where the doors still couldn't be removed without cutting the bolt as it locked the doors solidly together.
As for man doors I've seen a few with upvc doors fitted just a hole cut flat plate welded round the door stood in the cut out and two bits of plate to sandwich the frame in place and a whole load of mastic to seal
Any ideas ???
these guys used to be the go to place for body fittings
sadly binned their extensive fittings catalogue but they deffo did the container door closures
just found these too https://www.cbf.uk.com/products/index/944
kind of defeats the security though .... flat frame welded in as said or better still an angle to give a slam then make up a door with box section and a plate face ... some weld on hinges and a couple of triple throw mortice locks ... job did
https://www.fhbrundle.co.uk/products/0515151180__28_x_180mm_Weld_On_Hinge
there was also Perkson Forgings (who made a lot of Jaggers stuff -- I discovered :giggle:) -- sadly I have yet to discover a website/online presence for them .. and binned their vast catalogue :cry::cry::mad::mad::mad:
You would think so but tbh watching the police programs on tv those euro doors are amazingly strong
If you then stuck a piece of steel over them even if you just used gripfill
And boxed 8n the lock and handle I think you would be on about level peggings with a homemade steel door
Fortunately Security isn’t much of an issue .
I just need to deter an occasional honest thief so any lockable door would suffice
