Slowmotion
Appears to be a Spicer COM-T4-2012 transmission.
Can anyone suggest probable cause and remedy?
Thanks old chap. Would the relief valve be internal/external?Gearbox Breather blocked
Or relief valve stuck shut
Wouldn't know but from your symptoms I'd say either or both might be give you the issueThanks old chap. Would the relief valve be internal/external?
No drive, Have changed the oil twice and each time I engage the shuttle most of the oil has been blown out destroying the filter.Does it drive at all? What is oil level like?
Thanks mucker. Have been reading on Spicers site and they say high pressure on any of the test ports indicates a failure in the control valve.return line/gallery blocked ... filter is getting full pressure with no where for it to go
