Case hydraulics question
Richard Hunton
Richard Hunton
A quick technical question.
Case cx300 in particular but probably common to all case machines.
The rotation and breaker lines.
The rotation is in the left hand joystick, the breaker line is on the pedal.
Is it possible to change the breaker line to the right hand joystick.
Had it done on my doosan so both are in the levers for my tiltrotator, but no experience of doing this to a case.
Any advice greatly appreciated
Rich
You’d need to add a cetop (assuming you already have a right rocker switch). You might be lucky and it’s already there, but doubtful if a pedal is fitted.
T whiting
T whiting
As above I know my breaker line's are servo controlled on the pedal so it shouldn't be to hard to add a cetop across the pedal.
Tbh I've not looked at how my rotation lines are plumbed but it's only push button rarther than a rocker
It won't be a CE top valve you will need it will be a feeder valve .
Does it have the roller on the right hand handle? If so it might have the hardware to do it! If not it will need a controller and a feeder valve in parallel to the foot valve.
I agree the breaker pedal (mechanical) Tandem the service flows would be greater than the offset ( button) which is a lot less and so slower.
