Case CX80C Error code 0101 7602 error message on dash Electric faults
3
3cpowertrain
Got a case CX80C where a message on the dash comes up Electrical problem.. all
Works but engine at full revs.. checked through all connections and fuses.. unplugged the top plug on the engine ECM and the message goes and leaves Error code 0101 cleared the message with the Jeltest Diagnostic and all fine for a couple massage came up again done the same process and again ok for a couple of days then the masses has appeared again.. on start up,.any help appreciated..
diggerjohn
Hi , did you ever get a solution to theses error codes ?
