Case cx15 travel levers.
Steve
So I have a 2008 case cx 15 here which tracks slowly (worse on one side). There is too much travel in the levers before they start operating the valves is there anyway I can reduce the free play with adjustment. The valve block is bolted directly to the underside of the floor plate with no visible external linkage.
Thanks for any input.
You’d need to remove the linkages and weld up and drill a new hole if they are worn that badly. Did it with my old Schaeff.
