I have only limited experience of the larger Bobcat 610 or 611 of this era (& years ago) Found this group dedicated to the older clutch Bobcats, & within it a private group that can help.
Melroe Bobcat Owners of America. 1,054 followers · 1 talking about this. Please join "Melroe Bobcat Owners of America Group"; the group format is much better exchanging information and submitting...
www.facebook.com
Basically a chain per side runs one way round one sprocket & backwards over the next beside it. Plate clutches pick up on either of these sprockets in turn to drive a secondary chain. This was how the forward / reverse happened on each side. Think what happens on a small Navvy such as the Cub but this used two large gears to the plate clutches. I would say the larger 610 / 611 (1.5t) would be much easier to repair. The last clutch type Bobcat was made in 1982.
I think the Belgian built machines of this era were pretty much identical. A variable driven pulley was upstream between the engine & plate clutch shafts, with a vee belt passing over it from the engine? (I think)
There was the original '70s Case 1816 but this had a worm primary drive - hence one fixed speed, thought not to be so good as the Bobcat, looked outwardly similar though.
A local man Hedley 'HJ' Kirk had several for hire with attachments pre mini diggers, This firm moved to Wem from Jackfield & the sons traded as A & D Kirk.
Later they seem to have re adopted the old HJ Kirk name? I think they were a Bobcat agency at one time. I think the move to Wem was to do with the machines being later seem much more as a farm machine than on civils - post mini diggers. The European built ones were much more likely to have brakes, these were on the front axles, otherwise you had to feather the reverse clutches or indeed use the bucket
