diggerjones
I'm after outer sheathing for the stop cable for my 180. I've got the inner cable, its 3.5mm. I'm struggling to find the outer. Any suggestions much appreciated
Sounds a bit excessive for a pull stop. Replace the whole lot with 2.5mm inner?I'm after outer sheathing for the stop cable for my 180. I've got the inner cable, its 3.5mm. I'm struggling to find the outer. Any suggestions much appreciated
www.speedycables.com
most off road motorcyle workshops would make you one up i would think but 3.5 mil sounds overkill for a stop pull cable what length are you after and does it have to have a specific end or could you sort that. other places may be classic tractor places.I'm after outer sheathing for the stop cable for my 180. I've got the inner cable, its 3.5mm. I'm struggling to find the outer. Any suggestions much appreciated
have used a liner and 1.6mm wire before now for a very long cable on a crane ... worked fine and easy enough to replaceWhat about a bit of Mig wire and a torch lead liner?
I've never tried it but recon it would work.
should've said 1.6mm Stainless wirehave used a liner and 1.6mm wire before now for a very long cable on a crane ... worked fine and easy enough to replace
About 2 m . I'm trying to put back what was originally on it. Its had a length of thin bike cable down it for years. Now the outer is knackered i thought I'd do it proper. I've already got the cable thinking the outer was ok.most off road motorcyle workshops would make you one up i would think but 3.5 mil sounds overkill for a stop pull cable what length are you after and does it have to have a specific end or could you sort that. other places may be classic tractor places.
Stop cables on older tractors are usually solid wire around 1.5-2mm with an outer to suit.About 2 m . I'm trying to put back what was originally on it. Its had a length of thin bike cable down it for years. Now the outer is knackered i thought I'd do it proper. I've already got the cable thinking the outer was ok.
