Bobcat E14 Mini digger with fuel issues
A
Anygmatic
Hi,
I have a 2012 Bobcat E14 mini digger with a Kubota engine. I am having fuel starvation issues - sometimes on idle, but more noticeable under load. Done the obvious (cleaned fuel, new filter etc) but still no better. I've had the issue for over a year, but it's slowly getting worse - and the machine only gets fairly light domestic use.
Digging around, it seems like the fuel sender unit could be at fault (as I also have an inaccurate fuel gauge which seems to be linked with sender unit problems so could be a double-whammy). On consideration, I'd probably be better off trying this rather than a new injector unit etc (£££).
Has anyone had any experience of this, and any info on the sender unit replacement? Seems like youtube/the internet doesn't have content on this specifically, which is unusual.
Thanks.
check for gauze filters in any banjo unions in the fuel lines
