O
OBL
Hi guys, wonder if you can help?
My 2015 E10 with about 1000 hours has its first ever fault...
The button that swaps between expanding the tracks and the blade control is very intermittent, often takes lots of times flicking between the two before it’ll entertain doing the tracks. If I track about a bit and if I keep trying it eventually gives in.
Obviously it fails mostly at crucial times when you’re under pressure!
Is this an easy fix? I’m assuming some kind of electrical diverter valve as it’s a button not a lever. I can hear it trying to engage but when I flick the button it often won’t do it. I do service my machines myself but I’m a builder definitely not a mechanic... sooo which out of the hammer and WD40 I have in my tool kit to use first?
Cheers!
Cheers!
