Benford HD1000 Dumper cutting out
Berry44
Hi Guys
I have a Benford / Terex HD1000 Dumper and it has a fault, it will start and run for maybe 3 to 4 mins and then cut out when it does all lights / electrics are gone
If I leave it a few minutes I can start it again but it repeats the fault, can anyone point me in right direction or is their a common issue ??
Powerfab
Powerfab
Electrical gremlins. Usually the culprit is a connection on one of the relays or isolators within the control box.
Mine used to do it intermittently, a smack on the side of the box with palm of the hand was often enough to jiggle the connection.
Eventually stripped it out, cleaned and reconnected all the spade terminals and hasn't done so in a long time.
It might be an interconnect isolator from the hydraulics or filter, but that's usually a repeatable occurrence.
I think some one had a similar found they asked about on here a while back :unsure:, I think that one was a control box under the dash, that water was getting it.
jd6820
jd6820
I'd be checking the circuit breakers on the side of the dash then the emergency stop button. Then report back to us.
