N
NickM1984
Good afternoon everyone. A customer of mine has an Avant 860 which won’t start. It’s used in a quarry as a loader and sweeper. It does live outside permanently in the elements.
According to the operator it just came to a stop one day in torrential rain.
This model has the stage 5 Kohler engine with DPF filter.
Firstly the ignition key wouldn’t even turn in the barrel so I fixed that.
Fuse for the dash display was blown so replaced that. Now display comes on with ignition. At this point the fans would normally come on as part of the starting sequence but they do not.
There is a red warning light on for the engine and fault displayed across top of screen saying ‘loss of CAN communication’.
Only fault code stored on dash display is to do with throttle housing. I have checked throttle and wiring all looks good.
I used basic TEXA to read fault memory and it came up with ambient temperature sensor. These faults could be deleted but after ignition cycle they re-appear. I’m sure that these faults wouldn’t stop the machine starting. Confused and starting to scratch my head I opened up and went through both fuse boards and all relays with nothing obvious found. At this point all plastic panels are removed.
It was very clear that the machine has been rained on constantly for 3 years, when I unplugged one or two connectors and let the looms hang downwards rainwater poured out of the loom shroud. Quite alarming and worrying. So I then unplugged all looms and hung them downwards to drain. I couldn’t see how it was possible to get this much rain water inside the harnesses especially as they are well covered by plastic body panels. Although the wiring harnesses were full of water I couldn’t actually find anything physically wrong. All wires and connectors themselves were in good order. Plugs were dry inside. The owner assured me the machine has not been sunk in a pond and the machine is clean and tidy looking so I don’t think there’s been operator foul play
Water drained out overnight and connections clean and dry the next day.
Still won’t start.
I’m quite new to the stage 5 Avants and would really appreciate any help or advice. I do have access to full wiring diagrams but honestly don’t know where to start. I have an incling that an ECU may have popped because there’s nothing physical staring back at me.
Thanks a lot guys. Nick
Still won’t start.
