As above- need someone to turn off the bloody deadman switch and stop the lifting mode being default.
What type of switch you got for the dead man is it like the ones in the up to 3t as a little splinter of wood gold them on and it works as normalAs above- need someone to turn off the bloody deadman switch and stop the lifting mode being default.
It’s one where you press it once you’ve put the deadman down and it springs back up but beeps and tells the ecu to release the servos. Not sure it would work being held down all th time. Also want the lifting mode to default to off.What type of switch you got for the dead man is it like the ones in the up to 3t as a little splinter of wood gold them on and it works as normal![]()
Ah I kept the ‘to go’ switch active, it’s not a bad thing and you soon get used to pressing it , and I’m on/off all the time! Also thinking about it one of our family friends probably wouldn’t have lost his legs if the machine he was near had such a system fit!It’s one where you press it once you’ve put the deadman down and it springs back up but beeps and tells the ecu to release the servos. Not sure it would work being held down all th time. Also want the lifting mode to default to off.
