F
fred
they do a 12v kit to power it, motorhomes use it.3 amp would be good, but it is running off shore power - 240v mains hook up. Not that viable for me.
Not looking good then. I thought it would be easy just to wire in a 12v unit and away you go.An automotive type alternator isn't going to like running at such high amps continuously, keeping it cool would not be easy.
To stand a chance of working it would take a much larger marine type alternator with inbuilt heat sensors along with upsized pulleys and drive belts.
You'd probably have to provide more cool air in the engine bay and a larger battery too.
Be surprising how much a bigger alternator would pull a little engine down as well at full output.Not looking good then. I thought it would be easy just to wire in a 12v unit and away you go.
Trouble is I still need to upgrade the alternator which seems may produce unwanted side effects of overheating and loss of power.Specs from the their Ac/DC converter.View attachment 16945
I was going to say about truck ones, but can see you have already found them.Every summer I think about fitting air conditioning to my mini digger. I really need to operate with the cab closed because of contaminated dust. I have a couple of 12v fans which help, but it is still too hot for a lot of the year. Has anyone retro fitted it to theirs?
I don’t really want a roof mounted unit for fear of knocking it off. I saw this wall mounted truck unit
https://www.kudauk.ltd.uk/product/1...nditioner-perfect-for-vans-campers-motorhomes
Any advice?
Thanks
www.zerobreeze.com
That looks very interesting. I'll look further into this.![]()
ZERO BREEZE Mark 2 AC
ZERO BREEZE Mark 2 Battery Portable Air Conditioner, Just press the button and enjoy the cool air anywhere. Get yours at the ZERO BREEZE Online Store now!www.zerobreeze.com
Just found this. Says it runs off 24v OR "up to" five hours on its own rechargable battery, the "up to" part is worrisome.
I understand where you are coming from, and on my bigger machine I probably would go down this route, but on the little one it is just a rats nest of pipes and cables under the cab it would be very difficult to traditionally mount the separate components. That and you don't see many 12v machines with aircon.Just a thought, is it not possible to find a machine for breaking and Rob the air con components off it, obviously it will require modifications etc, but at least your starting with something that was ment to be run on a similar system to yours ie, excavator engine, 12 or 24v.
