Broken machine, customer damage?
P
Plantandcrane
Hi Guys,
New to plant hire as ex building so loads of knowledge about machines etc.
I’ve set up a small plant hire Co mainly smaller micro stuff, use CPA terms and conditions for hire etc.
Just had a break down call, con rod through the side of the engine, what’s my options as the machine been well maintained and was running great when dropped off.
I’m thinking customer has not checked oil, or tipped machine and ran it.
legally what can I do under the T&C’s ?
any help and advice appreciated!!
Danny
Danny
Do you have pictures before the hire any tell tell signs it's been on its side?
I had a 13t machine a couple of years back that had £8-10k worth of damage on a week's hire. But when he phoned up for it, he seemed like a know it all so I made sure he took out insurance and emailed proof before I sent the machine out
P
Plantandcrane
I’ve not seen the machine yet as only got the call this afternoon, my question is a suppose can I charge for this damage if it has been tipped or neglected?
Regy53
Regy53
I like cake
What machine is it? I doubt you have a great deal to go on unless you can see signs of tipping. Thwaites would bend a rod if not more when tipped on side... Terex would not do anything
To be blunt I'd be surprised if tipping resulted in that damage..... Normally they just hydrolock and at worse will break rockers/valves
:ROFLMAO::ROFLMAO: Ever seen the results of a runaway?
Also it depends how long it ran after being tipped. An engine will splash feed for a time and survive, but in a mini/micro where they normally end up on one side, the “top” piston and bore will get starved, and end up with a damaged main and big end, scored bore and knackered piston.
P
Plantandcrane
It’s a Kubota k008-3. It’s in a long garden down a hill so recovery will be a nightmare 🤯
Assume they booked a micro because its awkward access.
Would it be just as easy to lob a lump in it in situ? If it's thrown a leg out the bed then it's new lump time anyway.
Send a bill in for it. If they are honest and guilty they will pay, if they aren't they won't pay but either way you need to get machine back running and onto next hire
I've seen several small machines tipped and haven't seen one take off yet 🤔
