opinions on performance, the merits of the telescopic telehandlers and telescopic loader loaders
hi guys, walking around the farms and farms I saw that many farmers use telescopic telehandlers as weight lifting service loaders to load unload goods loads like small cranes and forklifts, with buckets to move inert materials, what do you think of the blades telescopic boom tires. can telehandlers be used to dig? what force of tearing and penetration do they have? enough to dig? which the best telehandler? I guess JCB .. let me know
They don't dig very well in comparison to a loading shovel
My godfather had a cat th62 with 4 in one bucket and used older it for digging lakes it snapped several front axles in short order so he bought a fiat Hitachi drott
They aren't heavy enough really to dig into ground and the boom geometry isnt great for this either they are ok loading loose material but again they struggle where a similar size loading shovel won't
They are brilliant with a muck grab that is easy to push into the material and generally have good tear out force to break the muck out and bale handling they are so much better than a loading shovel
he owns a mechanic, a fixer in the area. he buys and sells used vehicles and machinery, he is trying to propose it and to place it to us villagers in the area. I assume not a good business but a bin. Thank you for your intervention, I believe it is best bachoe solution with forklift fork for farm maintenance farm work and for small jobs in agricultural fields. thank you for your precious suggestion
get your self a nice duck :giggle::giggle: .... job done ;) :cool:
Quale sarebbe una bella papera? mi prendi gioco dell'umorismo inglese. Non capisco? non pensi che sia un buon escavatore o mini escavatore al posto del telescopico telescopico? Mi dispiace se sono noioso e petulante, non sono un esperto veterano professionista, ho molto da imparare, grazie per il tempo che ti faccio perdere. grazie
" What would be a nice duck? you make fun of English humor. I do not understand? do not you think it's a good excavator or mini excavator instead of a telescopic telescopic? I'm sorry if I'm boring and petulant, I'm not a seasoned professional veteran, I have a lot to learn, thanks for the time I make you lose. thank you "
sorry boyo ..... not being flippant as such .... a ''duck'' is the slang name for wheeled excavators ;)
the M1400 is a nice tool and quite a few scattered about Europe for sale at the moment :)
un mio amico meccanico mi ha consigliato contro gli escavatori gommati, mi dice che per il bilanciamento della macchina del baricento e della struttura meglio tracciata. è più stabile ed equilibrato anche se lento, il gommato mi dice che è più adatto per lavori stradali o piccoli lavori. li vendo e li ripara, ho solo esperienza con piccoli caricatori gommati.
ps: I tell you a curiosity about the duck synonymous with excavator. in lombardy it is called "Pàchera " motopala,motopala in sicilia calabria and south of italy- scazzega
nella valle di montagna di Aosta Trentino Alto Adige. ma è un gergo da escavatoristi ruspisti. le persone che non sono abili nei lavori ignoranti in materia chiamano tutte le macchine movimento terra escavatori, i bulldozer con livellatrici con una sola parola che è sinonimo di macchine movimento terra, cioè: RUSPA
https://www.tericordetlaives.com/pachera
" a mechanical friend of mine advised me against the wheeled excavators, he tells me that for the balancing machine of the barycentric and of the structure better traced. it is more stable and balanced even if slow, the rubberized tells me that it is more suitable for road works or small jobs. I sell them and repair them, I only have experience with small wheeled loaders.
ps: I tell you a curiosity about the duck synonymous with excavator. in lombardy it is called "Pàchera" motopala, motopala in sicilia calabria and south of italy- scazzega
in the mountain valley of Aosta Trentino Alto Adige. but it is a jargon by escapatoristi ruspisti. people who are not skilled in ignorant jobs on the subject call all excavator earthmoving machines, bulldozers with one-word graders that are synonymous with earth-moving machinery, namely: RUSPA "
Much like JCB is synonymous as a 'universal' description of a digger
yes a tracked machine is more stable on a flat surface, but a duck in the right hands is a VERY capable machine and possibly more stable on an uneven surface as it is possible to have all 4 wheels solidly 'planted' on the ground ... they will both start to tip at the limits of their dynamic stability ... a duck is a very versatile and mobile machine, but the tracked machine will have the upper hand on cross slopes, due to its lower centre of gravity
I have to be honest as excavators are denied I rely on the most competent forgives of me my mechanic friend who repairs them hires and sells used tells me that the crawler climbs dapperutto has the lowest center of gravity is more balanced has a better set-up. I have never tried the excavator in his opinion the best is the 12-ton blade runner with open blade type bulldozzer track tells me that how it works is better than a versatile wheeled backhoe. I refer to your statements, clearly if you have other opinions, I invite you to intervene, I am an ignorant person who wants to learn thanks
the Kobelco Bladerunner has a very good reputation as a great versatile machine
I'm sorry if you get bored with my questions, what do you think of the jcb Hydradig wheeled excavator. is it really as reliable as performance? and old JCB js 70.75 jcb model, 80 years of construction 90/2000, I believe built in cooperation with sumimoto? Thank you for your precious time and your sincere and objective opinions thanks.
marmite !!!! :unsure::giggle:
https://it.wikipedia.org/wiki/Marmite
boy? maybe, you fool me with the usual English humor, I thought you were nationalists and exalted the products of mother fatherland england, however, if you felt the queen, or carlo, however, I hope that your opinions on hydradig are true, I believe that not I will be disappointed by this earthmoving machine mentioned above, by us that we are backward will never come to work, we still use the fiat and its surrogates. as above: water is scarce the duck does not float. I'm not very familiar, how long does it take to become a good professional escavatorist, not being a boy anymore and having little time available (of course, life left) still your modest experience? any suggestions from a professional veteran expert in the field?
Marmite is a spread for bread Boyo, with an 'acquired taste' :oops: ..... you either love it:love: or you hate it :mad: ..... the Hydrapig has been described as a Marmite machine :LOL: .... let's say it has a few foibles, putting it politely :rolleyes:
Charlie
Charlie
Now he just has to work out what a foible is 😂 and it’s not part of a sword in this context 😂
Charlie
Charlie
Your reply translated into Italian and back into English :ROFLMAO::ROFLMAO::ROFLMAO:
The Marmite is a diffusion for the bread Boyo, with a "acquired taste": oops: ..... or you love him/it: the love: or you hate him/it: crazy: ..... the Hydrapig has been described as a car Marmite: LOL: .... we say that it has some weaknesses politely setting him/it: rolleyes:
