Mikey
I'm planning on changing the oil tomorrow in the final drives my tb108. Looks a straightforward job according to the manual. Position the holes as per diagram, remove plugs, drain oil, fit bottom plug, fill with oil until it comes out of upper hole, fit upper plug. The manual says to wrap sealing tape around the threads on the plugs, any ideas on what to use? Is it the same stuff, PTFE, as used on plumbing fitments? Any input would be greatly appreciated.
