How did you think the trees reproduces ?
Is it mixed with hanging birch?
Ole Kristian Kjeldsrud
Cut with the stack down
Kjell Østrem
Let it stand
Leiv Arne Bødal
Cut above and below. Then turn the log upside down.
Anders Bjørnereim
Leiv Arne Bødal and saw him in the yard as a two-temple. UGH!
John-Ole Sandvik
Dissolve Viagra in a little water, empty it over the roots and wait a bit. Then you can saw off the branch
Morten Kvingedal
Wait for sevja stig, send update ...
Kristoffer Nerhus
Then you get cheese!
Yngve Haugen
If this is a breeding spoon, leave it until spring, then you will see ...
Kristian Verstod
Let it stand
Ragnhild Alma Vinkenes
Tøvkaill, but since you ask, I must explain the procedure for shedding aspen
- chop down the aspen
- cut into suitable lengths
- drive home
- put on the saw
- cut planks and or boards, depending on what you need
Georg Jårvik
This one just has to hang !!
Håkan Tapio Pettersson
Do not touch. This is typically hengosp å is Tip tip tipp great-grandfather to the whip
Arne Øversveen
Let it stand
Stian Bakka
The one there you have to take at the root
Oddbjørn Haugen
Suggests lasting protection
Lasse Lyngmo
keep your distance! it can be contagious
