Russell
I've got a job where I might need to winch myself out if i get stuck. I'm thinking I'll fit it on the dozer blade. Those ears must be strong enough to drag it out some slop or up a hill?
If you are in the shite though, you want to come out blade first, IMO.
E10? Might as well use a tirfor winch.I've got a job where I might need to winch myself out if i get stuck. I'm thinking I'll fit it on the dozer blade. Those ears must be strong enough to drag it out some slop or up a hill?
I will respectfully disagree. You can lift the front of the machine and pull yourself up and out of the shite, with the blade in front of you keeping it out of the shite, hopefully….But if you are blade first and the blade is digging in then you need to lift /pull urself with the boom which would give worse geometry than trying to lift the blade and push if you are going backwards.
But tbh I don't think the winches are really designed for self recovery more slope working
If you try that with the blade behind you then it’s an anchor.
Just my opinion, and yes I’ve been in the shite on many occasions.
you sure that's going to be big enough ?I've got a 13,500lb one coming for the E10.
I know it's a bit oversized but, at a later date, I might stick it on the disco and get that stuck in some mud too.
but if you're facing downhill you'd want the blade in a similar direction, surelyI've got a job where I might need to winch myself out if i get stuck. I'm thinking I'll fit it on the dozer blade. Those ears must be strong enough to drag it out some slop or up a hill?
that makes sense, but if going downhill you'd surely want your blade downhill tooDrive into Poo with blade behind you so if it starts to go south you can still get out......
Personally for a E10 I would be mounting the winch elsewhere..... Trouble with putting it on the stricken machine on a bog is you have no ability to alter the ropes trajectory.....
Not in slopthat makes sense, but if going downhill you'd surely want your blade downhill too![]()
aye .... " but sh1t runs downhill "N
Not in slop![]()
Who the f**k is EMYH?
