From a flail mower. Standard roller bearing in a housing, the inner side has a turned lip to guard against wire ingress. Outside looks like a taper lock of some sort around the bearing, but I can’t see any indication of there actually being two parts (it looks all turned) so I’m wondering if you press just the bearing out? Good excuse to order that 50t press I’ve been after. First pic is outside.
It has to come out the outside way- the plastic seal barely fits through the inside turned lip/guard. Due to that lip, the only surface available to press on is the inner race.
