Mogmans creations 🤔
unpaid fun generation :giggle::giggle:
Dunno about that - I reckon any day Paul spends ‘extreme tinkering’ in his scrap yard probably leads to a highly profitable outcome, either in improved efficiency at a later date or in creating something valuable out of something that’s been chucked away.
Uncle Bulgaria or Tobermory might be better names for him than Mogman possibly...
My dad always says if you enjoy what you do you will never have to work again👍
that’s my trouble if it was left to me I’d never go home only to eat and sleep😉............hang on a minute that’s what I do😳😆😆 much to mrs mogs annoyance 😩
sounds pretty familiar ...... in a previous life :rolleyes:
Had a look at mogs handy work today while borrowing his lathe and 20mm plate cracking job on the digger should be a good tool when it’s done
Cheers fo the vote of confidence 👍
hope your wheel rim adapters work🤔 this is how I left them after I’d cut them out 😉
Davedb
This is what they became did the turning at mogs as our lathe isn’t big enough then bit of careful marking out this morning and drilling with the old trusty pillar drill (dads had it 50years no idea how old it is)
no idea why pictures are sideways they are fine on my phone🤷🏽‍♂️
This is what they became did the turning at mogs as our lathe isn’t big enough then bit of careful marking out this morning and drilling with the old trusty pillar drill (dads had it 50years no idea how old it is) View attachment 22058View attachment 22059View attachment 22060View attachment 22061View attachment 22062View attachment 22063
no idea why pictures are sideways they are fine on my phone🤷🏽‍♂️View attachment 22064
Cracking job Dave👍 see I knew you could do it😉
It looks like a denbigh drill, we used to have 2 of them. We updated to a set of 40yo Herbert 😆
It’s alive 👍👍
still a bit to do though😳 the radiator seems to be blocked😢,
what do people recommend for flushing it, it’s all aluminium construction so if need be i’ll have to cut the top off and poke the core out but will try the ‘easy’ option first
also all the rollers, top and bottom are seized as it’s been stood for well over 6 years😳
Davedb
Dishwasher tablets work quite well but don’t leave them in too long as they are very salty and it won’t to the Ali much good, good to see her going
caustic soda normally ... but doubt an ali rad'll like it a lot ..... steradent are pretty effective too, but needs to be hot and bang 10 in there .. leave the cap off though
Update time👍been out earning money for a few days but managed to back flush the radiator by making an adapter on the steam cleaner and getting it flowing full bore👍
but I think the ’new’ engine maybe worn out😢 when it was on the baggage conveyor it seamed fine🤔 but now it’s labouring and black smoking a lot when you operate the levers and if not running flat out will stall😩 plus getting very hot🥵
so going to pull the air filter out and stick an electric fan on it as the engine fan is about 6” from the rad and is missing the shroud but it that all fails need to source another engine 😡 but hay ho 🙄 oh and one of the steels in the track is coming out😯 but on the plus side freed the top and bottom rollers off👍
Davedb
We went to one of these in a digger once doing simlar tried everything then eventually a Perkins expert said to take the injector pumps out and have them done, the diesel specialist said they couldn’t really find anything wrong but refurbed them anyway and that cured it straight away seems there’s something that wears slightly just enough to upset them
Had a good think yesterday and decided to pull out the underpowered Perkins out for a bigger unit, tried an electric fan but still got too hot plus it seems hard work for the engine the original one was 28Kw but the Perkins didn’t have any plates on it so a bit unsure what output that had,
So plan B pulled a deutz engine from this 40Kw too👍
it’s a fair bit bigger than the already bigger Perkins motor😳
first job get the pump to fit🤔 now the deutz had a large pump fitted but was a forward/reverse drive unit so had to come off and a new boss made for the komatsu pump
luckly the cast bell housing has a bigger hole so made a bush to reduce it to the new pump
so with a couple of new threaded later ended up with this
that then mounted to this after I’d made the new drive rubber fit🧐
just got to shoe horn the bugger in🤔
