Vinnys Ventures
Here we go . The posts might be a bit sporadic by the time I’ve filtered out all the pics where the h&s boys and girls might raise an eyebrow or we haven’t got the right ppe on or we might upset the clients or main contractors or other contractors I’ve undercut !
I dont think any of the above will bother us here. You've seen what we all get up to right? 😁
T whiting
T whiting
That's why I try to take photos without people in it just causes less issues
looking forward to this thread :giggle::giggle::LOL:
I recently cut this drive in for a neighbour, they had a shared drive on the other side of the property so this made more sense for them. I done it with the duck . I finished it after this pic with tar plannings which is holding up well
This is underbuildings we are doing for a local contractor . The houses are very low energy and use renewable resources wherever possible . We get the pads completed , all the drainage and landscaping done and the services where possible before they come to site with the building .
Is that next to the boat house? We did steel work for a few houses in findhorn in the last 2 years.
Hi Mike
Yes it runs from the marina down behind the houses to the centre of the village . We started it just before the lockdown and finished it once we got back to work . The spec is a cedec finish for most of it and some areas were concrete . We actually thought it should all be concrete as the path floods in places during high tides . There is a new house backing on to the beach the path runs behind , did you work on it ?
We did a steel A-frame for a glass gable, it was a stone throw from the boat house. Was built on what seemed like a sand bank. Only ever seen it at foundation level when we put steel in. They normally do a good finish on their houses though.
Yes that’s the house , it has a big garage with an annexe above it as well . We took a branch off the path behind that house down to the driveway that accesses it . It’s a small world . Do you do much other work up this way ? I seen in one of your previous posts you’d been up about Invergordon
Not a huge amount, findhorn is only about 40min from us, we do bits at invergordon distillery. We're mostly around Speyside.
