Recently gone from a mini with 25 mm pins to one with 30mm pins - pin centres are same (vclose)and so is dipper width - i want to keep some of my bits from the old machine......Initial thoughts were a mix n match hitch but I want to keep the buckets that came with the new machine with 30mm pins.
So options seem to be open up holes in 25mm buckets / breaker / rake etc or weld some 30mm bar in-between the bosses but will only be able to stick it with the welder through the bosses which might not be strong enough
Whats peoples thoughts ?
I dont have access to any big drills etc
