dod
Anyone any experience on one? I like the brand. And the 14tonner with a blade and king post idea. Just never seen one in the flesh never mind driven one.
Looks like something to put the £50,000 government loan to.
that with a VA boom'd be some weaponNo experience on this model, but I love the brand
Have own a baby 1503RD mini for the last 10 years or so.
In that time it's been 100% reliable
Had a gander at the model you are asking about and now I want one.....
Wacker Neuson ET145
But I will follow this post with interest![]()
I prefer the conventional boom on my 8 tonner let alone a 14!!!I think kingpost on a 14 tonner makes them a bit light duty. Admittedly makes more versatile in a tight spot but I'd look at conventional style boom. Blade is handy and most manufacturers offer it as option on 14 tonners but it's not that common to see.
Takeuchi are more commonly found in austria than wacker neuson as well, market leader over there for mini and midi excavators.Takeuchi do a similar model which is more commonly found.
I had a demo of 9 tonner. Im sure they are the same. Thought it was amazing!!Wacker Neuson is a very under rated Brand. But get a demo first! I've found there model range to be very hit and miss with some machines being absolute weapons (there 1t hi tip dumpers for example) and others being a dithering disappointment (think there 8t machine was the one I was saddened at at plantworx)
Few of them round here. I just start looking like the competitionTakeuchi do a similar model which is more commonly found.
Thanks for that. I have 8 tonners but they are sometimes a bit small. It mainly civils and round houses we are working. Can buy a JS160 say for very little money comparatively but feel I wouldn't use it on a lot of jobsI have spent time on two of these machines, both with blade and two-piece boom. First thing is, they look small for a 14 tonner,, but that’s down the the thickness of the steel used. They are very stable, having a lot of low-down weight. Not the quickest of machines, but if you’re doing heavy civils they’re a good weapon with the blade and offset. Handy on housing sites or anywhere else with restrictions. However, if your main work is production, go for a conventional machine. The ET would never keep up with a Hitachi, Volvo or similar on truck loading, ditching, etc, but if that isn’t a consideration, go for it. Or at least have a test drive.
I know a few folk like you. I however love having a kingpost. Having a tilty has given me all the usual benefits but i like working my bucket out my side doorI prefer the conventional boom on my 8 tonner let alone a 14!!!
I wouldn't dispute they have enough metal in them i just think above 10 ton go conventional boom unless you've got a lot of specific work for the kingpost machine. I'd reckon a 14 ton zero swing would be more compact than the et145.missed your bit, Gaz. Obviously the king post does detract, but have a look at one and you’ll see that Wacker put the meat where it’s needed, and you’d have to hammer one and not grease it to kill it. As I said above, they aren’t the fastest machines either, which helps life.
Interesting pointI'd reckon a 14 ton zero swing would be more compact than the et145.
I quite often run with offset round so im looking out the door as well, but it's worth noting on a kingpost machine it's usually so you can see the full bucket without looking around the boom as its mounted further forward. Not an issue on regular 14 ton class where boom is mounted beside you.The ET145 doesn’t have much arse, and with the two-piece boom (I’ve operated mono and two-piece ET’s) it folds back further than any mono boom machine the same weight, and by a big margin. Even a monoboom folded round, like Dod says he likes working, reduces the envelope quite a bit.
One problem when thinking about a different machine like this is perceptions. I can remember when rubber tracks were a waste of time on a machine over 5 tonnes, now they’re fitted to 15 tonne machines and surviving. Same with offset booms, they’re getting fitted to much bigger machines nowadays and surviving. Offset will never outperform fixed for some work, but in the right application...
