Sub 3t Excavator - towable
I
IvorT
Seem all around 26 - 32k new
Kubota ? - limited warranty and most expensive
CAT ? - 2 yr warranty
Takeuchi ? - dated cab ?
Hitachi ? - no air con
Some come with AIRCON any pro and cons
Any advice appreciate as it will be a replacement for a 15yr old KUB
I did a thread on this couple years ago called best towable or something like that.
I don't think there is a bad machine out there of the mainstream options, it's really a case of 6 of one 1/2 a dozen of another depending on what your looking to use it for. I reckon any of us could argue our case for a given brand but best thing is go and have a look and see for yourself, then when you've shortlisted a few options see if you can demo/hire one for a week because it's really when you get into using them for a bit that you start to discover idiosyncrasies!
I
IvorT
yeah i suppose should of also asked ......
Any issues to be aware of ?
Good points on any machines ?
Had a couple of larger units new that have had issues that one manufacturer couldn't fix so they are now not even under consideration
Are you after a conventional tail swing or Zero? And what will be it's main line of work?
would chairman row swear by a sany?
local utility lads using one seemed happy with it
yanmar looks a good machine
im looking for one soon as well the might kx71-3 feeling a bit tired and not a cosy place to spend a cold wet day
Yeah I'm keen to have a look at the new Yanmar sv26-7 too. Seems like they've improved a few things over the old model.
No air con option. I'm still torn how much use it really is on small machine where there the default positions seems to be window open and in and out alot anyway- good for demisting when it's wet though
Couple of arb ones round here they look smart!
Arguably best looking mini..they seem to have focussed on arb market a bit
I'm still going to say Bobcat E27, I'm on my second. But I'd always try the competitor models just like I did last time.
Bobcat wins for me on lift capacity, short tailswing (buy the E27, not the E27z) and comfort. If I was only groundworks (I'm 90% deveg/arb) I would look at something that might grade nicer though.
