God knows what a new model specced the same would cost. I suspect they’ve done some hours between them!
www.facebook.com
the biggest issue with that is all the leccy limiters .... hand grenade with the pin outPerfect for a waste handling station. Would need to remove the rail wheels and bodge up some RSJ beams either end for stabilizers.
Cheap for a reason. Presumably a clever man could bypass all that.the biggest issue with that is all the leccy limiters .... hand grenade with the pin out
given time ... would be a complex set up though, with multiple solenoid valves preventing/limiting all sorts of motionsCheap for a reason. Presumably a clever man could bypass all that.
Wondered that myself, prob still pumping out that lake he was on..and talking of rail work ...... WTF has happened to David Lynch (@Lynchy) anyone know?
if you're prepared to deal with all the inevitable issues that'll arise and assuming it's not done a billion hrs, it is a cheap duck .. biggest put off is the bad rep they have for w*nky valve blockswas looking at that earlier ,thought it was cheap tilty must be worth most of what the asking price is
Surely it can’t be that bad to remove the rail spec kit? Would it have started as a “standard” machine and converted, or factory built as a specific “rail” spec? Im thinking like when buying a vehicle that some clown has added alarms and wiring and you have the satisfying job of removing the added loops and linking back together!
Philmor Rail units ... converted in Blaenavon 10 miles away
now defunct .. started by Hugh Philips' boy, Adrian and Pete Morgan (now doing life in Caerrrdiff nick) ... Neil and Wayne Gregory (GOS engineering) bought it for naff all when they went bust.
https://find-and-update.company-information.service.gov.uk/company/03258228
will almost certainly be push button control for the tilty ... and they ain't 160s
anything is do-able Matt .. some one built/mod-ed itgiven time ... would be a complex set up though, with multiple solenoid valves preventing/limiting all sorts of motions![]()
Would have air brakes rigged up for trailers on that also limiters would have a keyto set the limits needed or none if turned off
Looks like a full fat tilty as 2 pipe job
Cummins B series I would say.on ebay this morning too
Komatsu PW130-6ES Rubber Duck Wheeled Excavator £12,750 | eBay
Find many great new & used options and get the best deals for Komatsu PW130-6ES Rubber Duck Wheeled Excavator £12,750 at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
this Kommy or Cummins?
Was my thoughts too - Cummins, which is in its favourCummins B series I would say.
lot of kit for the money ,rotator is worth ? 3 grand ?Was my thoughts too - Cummins, which is in its favour![]()
Well - I might have told my Landlord about these... and now its turned up in the yard! Its the one without Engon, and its got stabiliser legs between the wheels. He is going to fit a waste picker on it to complete his grab machine in the waste transfer station. 2002 / 8000 hours and Air cooled with a spare seat.if you're prepared to deal with all the inevitable issues that'll arise and assuming it's not done a billion hrs, it is a cheap duck .. biggest put off is the bad rep they have for w*nky valve blocks
were it not for the fact that it's not duck hunting season and I've already 'bagged' a 'Drema, I'd be tempted enough to go take a seriously good look at them ... very straight for their age, should in theory have been very well maintained, exceptionally equipped, rail wheels bolt on/off and I have seen blade set ups advertised for these on fleabay and a few leg beams ..... would never be a front line machine again, but a hell of a tool to have about for not a massive outlay.
