rubber duck thread :)
andy pandy
andy pandy
my fist go it alone moment .. was nearly sick after I took the photo
BertB.
BertB.
Some pics from the Western Front...i.e. Canada. These machines are from when the wife and I were living in Lethbridge, AB. Not many guys there know how to run them with the legs up so you often see the legs and or blade down....especially the city guys that use them to replace old water mains. lol The other machines as far as I know were used to dig house basements.
BertB.
BertB.
Couple of 'ducks' in Winnipeg one a 1085 Cruz-Air originally designed by the Drott company, later Case, and finally Badger. They had a number of design flaws a big one being a lack of reach due to the large tires so you had three stick options including the 'extendahoe', regular stick, and really long stick.
BertB.
BertB.
A few Liebherr's running around Winnipeg usually doing road construction as you can see I often have my wife take the pictures for me when I'm driving unless I have a friend with me. The Winnipeg duck operators are often pretty good operators as they know how to run them with the legs up.
BertB.
BertB.
Another Liebherr modified for Canadian National Railroad
BertB.
BertB.
Same machine I think a month or so later replacing railroad ties on the CNR Letellier Subdivision near my inlaws farm.
Couple of 'ducks' in Winnipeg one a 1085 Cruz-Air originally designed by the Drott company, later Case, and finally Badger. They had a number of design flaws a big one being a lack of reach due to the large tires so you had three stick options including the 'extendahoe', regular stick, and really long stick.View attachment 1358
you forgot to mention the built in tilt hitch on the Cruz Airs Bert ;) handy feature :)
Boom lift top pin looks to be well on the way out in that Cruz Air Bert :eek:
presumably the dipper is pinned to the boom, straight out for roading with those two lugs and hole in the boom head ??
IIRC they did a big bro to them didn't they? a real beast of a thing :oops:
only pix I can find of the Drott 80
twin dipper rams :eek: and rear boom lift cylinders ..... presumably they were 270 degs working only? .... or wipe the bonnet off job :( ..... or is that just a trick of the camera ?:unsure:
or maybe not ?? 'sa big Mutha :eek::eek:
duck with 'attitude' :giggle::giggle:
BertB.
BertB.
Yeah that was likely the first quick hitch on any machine on this side of the pond and the first to tilt. Found a few more Hyundai's from Lethbridge and Taber, AB. The first machines are used by the City of Lethbridge for water main replacement work hence the different selection of buckets for working in and around cages and other trench shoring. The plate packer for backfilling of course. The baby duck is my personal favorite as I tried one out a couple years ago and had a few idea's about putting one to work. The last Hyundai was privately owned and mostly used for digging house basements.
Yeah that was likely the first quick hitch on any machine on this side of the pond and the first to tilt. Found a few more Hyundai's from Lethbridge and Taber, AB. The first machines are used by the City of Lethbridge for water main replacement work hence the different selection of buckets for working in and around cages and other trench shoring. The plate packer for backfilling of course. The baby duck is my personal favorite as I tried one out a couple years ago and had a few idea's about putting one to work. The last Hyundai was privately owned and mostly used for digging house basements.View attachment 1399
IIRC that's what Ovlov market as their baby duck .... Found it incredibly 'wobbly' when I had a little time in one at Ovlov's "Big Dig Day'', last year:unsure: .. and travel was on or off :eek: ... nice cab though
BertB.
BertB.
It probably just needed dually's. I personally didn't find it that wobbly but it just had a wedge style quick coupler and a trenching bucket on it so not much weight there.
Next one is a Cat machine I ran nearly ten years ago already. Something that happens nearly every spring in this area is plowing of drainage ditches and in the city its done with 'ducks'. I had initially tried out with a so called landscaping company that had a couple Hyundai 140 size ducks and could handle the machine fine but a friend of mine cautioned about the company, so I went with this other company and spent about 2 weeks with this reversed Bateman tilt-bucket with what looks like a mailbox welded to the side. This was done as the snow was suppose to be pushed to the back slope of the ditch and the mail box was to make it wider and all it did was plug up and cause the bucket to want to tilt to that side every time you took a scoop.
svcivils
svcivils
My two ducks I have owned. Terex tw85 & wacker neuson 9503
was that Wacker on Ebay last year Scott ??:unsure: .... looks familiar ;) great lil' ducks apparently :)
svcivils
svcivils
Never had it on eBay. Sold it in july2016 was a great machine. If I had work and could afford to I would have kept it. Cab was basic. But was very quick and smooth. And 40k box and smoothride made it good for roading. I bought the wacker from Austria.
wee_gus
wee_gus
Can you tell me what quantity of oil goes into the axles? Been told of Hamilton brothers approx 2ltr per hub but the axles they could say.
You know of any common issues with them? A friend has bought a 2013 9503
Regy53
Regy53
I like cake
Not many of them about
