8–10kva generator recommendations
The place we did the flood pumping station have been on, on Friday when we had storm bebet they had a power cut so have taken me up on my idea to add a plug in and switch for a generator so I can drop one off for them in emergency but they like their own.
8–10kva 240 trolley mount small as possible
Any suggestion they’ll want it cheap as well not a Stephill etc
gonna be a Ying Tong then :rolleyes:
I can ask Serge (my genny mate) for his opinions/recommendations .. Budget??
New? Prob Hyundai...
Gateway normally have a rake of them otherwise?
The Hyundai generators aren't great tbh we have one at work a sizeable thing electric start but trips if used with any form of breaker. So only any good for the mixer.
We have loads of pramacs with honda engines and they are great really reliable well built and only marginally more expensive than the Hyundai
2nd that ..just thought they wanted cheap as
We've a 8kva sp petrol pramac that's bombproof
Rob65
I’ve just sold a 10kva 415v, 240v , 110v Arcgen last week.
It was ok starting a 5kva 3 phase motor.
To be fair it was probably a bit old and tiered for your application as it had about 3500hrs on it.
One question - petrol or diesel?
If you go petrol, assume the fuel lines are not ethonol compatible and should be replaced. Also, add a decent filter.
This one, they don’t like you finding information out on their website!!!
these look the sort of thing @Giles
You have to buy trolley kit seperate makes more sense
Going to get a shock lol £6k
They'll not get anything decent new for less tbh.
And then they need to think about service and maintenance...no point having genny that doesn't fire up on the button...
1.5kw x2 is really not a lot. Is fitting a soft start an option?
Not to doubt your sparky but plenty on here will happily run a 3kw 9” grinder off a knackered old 9hp petrol Honda genny.
