Trailer for sale
K
Komatsu
Off loading this trailer. Putting it up here before it gets dropped into auction,tyres are good, drop side, single acting ram, bed is 3mx 1.8, looking for £1250 or ono
What's the bed like Ollie ... presumably the ply is protection;) not hole coverage :giggle::giggle:
where is it standing currently :unsure: ... that'd be the big issue for me really, :( otherwise it'd be handy (even handier a metre longer ) :giggle:
you sure that's only 3m?? :unsure: looks more like/closer to, 4 to me :confused::confused:
K
Komatsu
yeh the ply is protection Gra, it’s in York, and it’s 3m long......on a side note, why is it that when you sometimes put normal pics up on here it turns them 90°?? or is it just me??
amazed by that Ollie :oops:.... looks way longer in the pix :unsure: ... but as you say some images distort :(
take it the eye is so high to go on your blade ?
York'd be a serious cost to Druid central :(:( ... 'bout 220 miles :unsure:
Just noticed the twist in that auger by the tail gate :eek::eek: :LOL: ... bit foo-ket:cry:
K
Komatsu
It’s that high just for the back of the machine, doesn’t really matter about it been on the blade cos you can adjust the height via the blade. It was literary just swan necked so to speak, so top bit could just be cut off and it put back to normal.......well if you can get a back load might make it a bit cheaper.....twist?? the damaged flight??
nah ... having zoomed it, it's the tip of one and the drive end of another, side by side ... looked like the one was twisted, at a glance earlier :rolleyes:
as for the step up .... your hitch must be at a hell of a height off the deck ... mines the usual 16" as far as I recall ... and yeh .. lop the top off and put a std eye back on - job did :giggle: .....
back load'd be the way .. it's just finding one :rolleyes:
are the upright posts welded to the side/head board or a free standing stand of some sort ?
What’s the weight of it....couldn’t you borrow/rent a trailer and collect with the P38 @V8Druid ?
still a bloody long way Boyo ... you'd want a fair trailer to load it onto too, to get the balance right. Would want to be perfect for that sort of distance :rolleyes: ..... a back load is favorite ... if one could be found :unsure: ... well up for it ;) and if Scotty could beam it up, it'd be great :giggle::giggle::cool:
K
Komatsu
I welded them in Gra, I put them there for my breaker, for when I was on the low-lowder, would place the chisel in between the 2 on the headboard, to stop it from sliding left to right. Then the one on the side was to keep it in place if I was carrying my crusher bucket, the breaker would sit parallel to the headboard with the chisel resting on the side. You can just see it on these pics.
K
Komatsu
as for the step up .... your hitch must be at a hell of a height off the deck ... mines the usual 16" as far as I recall.
Think you might find that mine is the usual for Duck's, you must be on Agri height 😉, wanted it so that it would sit level, as you can see she’s sat up a bit at the front. Think I sent you the pics/put them on here of my new trailer having the height altered so it would sit level. Full new draw bar rather than just cut and bend.
Think you might find that mine is the usual for Duck's, you must be on Agri height 😉, wanted it so that it would sit level, as you can see she’s sat up a bit at the front. Think I sent you the pics/put them on here of my new trailer having the height altered so it would sit level. Full new draw bar rather than just cut and bend.View attachment 8246View attachment 8247View attachment 8248
looks pretty much the same as mine that Ollie:confused: .... I'll go put a tape on it ..... when the large water droplets stop dropping out the not so blue yonder :mad: ... thought it was the usual 16" ..... but I may be wrong :unsure: .... can you stick it on the back of the tranny when you come down next :ROFLMAO::ROFLMAO: :oops:
K
Komatsu
looks pretty much the same as mine that Ollie:confused: .... I'll go put a tape on it ..... when the large water droplets stop dropping out the not so blue yonder :mad: ... thought it was the usual 16" ..... but I may be wrong :unsure: .... can you stick it on the back of the tranny when you come down next :ROFLMAO::ROFLMAO::oops:
I’d be surprised if it was 16”, most of the ducks I’d looked into were nearly the same all round, if I remember, when the old man got his trailer, he had it altered to suit his duck.....but I know what your eye site has been like of late👀😂😂....before I had it altered, I bought it back from the auction on the back of the navara...think it would be to low now, thinking about it, Nige had his trailer altered as well for the Liebherr.
OK ..... you got me wet :rolleyes: :p ... 15.5" to the bearing surface so 16" centre on a 1" dia. ring hitch ;) ... 4 bolt NATO type mount centres ...
can see it here - just ... factory fit .. would take a NATO hook too ;)
mounted quite low ....
see it a bit closer here ... a certain forum member assisting me in pulling a hose through, when I had a burst from the servo pump
'bout the closest pic I can find of said jaw hitch:rolleyes:
K
Komatsu
That is low, but I suppose designs move on, with ground clearance been one of the major factors.
don't know what I have under my leg pivot points, but suppose about 14" under the centre at the back end .... this gives you a reasonable idea of the back end Ollie ...
significantly lower than your hitch for sure .... could always make a lifter plate I suppose ;) ... but the leg ram pins're above the hitch point, so'd have space it out :unsure: .... do-able though ...... or put the eye back to where it was and it'd be at a std height then ;) .... main issue is the 220 miles between us :(
K
Komatsu
This is off a Doosan from out in Sweden the other year, you can just see the pivot pins behind the plate.
K
Komatsu
This is what CAT/Komatsu have on there’s, and what a few have started doing, should the trailer end up going on it’s side, it will just turn on the hitch rather than snap anything..
K
Komatsu
And this type of hitch was becoming quite popular last time we were out there..
60/75mm spoon hitches those .... very nice :cool: but a very nice price too :oops:
