Thwaites nimbus clunking sound.
jim53
Hi I have an old thwaites dumper which has developed a loud clunking noise when accelerating in all gears. Made worse when loaded. Any ideas on this ?
Thanks
jim53
Prop shaft joint?
Thanks I shall check the shaft joint. I did wonder if the drive chain on the clutch was jumping as it seems very slack. But the shaft joint seems more likely now you've mentioned it. It's hard to work out where it's coming from by one's self when driving it. Thanks again.
If it’s clunking badly it may be the sprockets worn out can you take the covers off the clutch?
jim53
The very similar Barford dumper did have a cover if I remember? I think this dumper needs the box moved to adjust the chain!
jim53
They are a bit worn but as you an see the chain is very slack too but as you suggest the sprockets are probably the cause. Any suggestions for getting spares ?
Thanks for your help.
jim53
Just moved the motor over to the right and that has tightened up the chain right enough and clunking has stopped :) was a nice Sunday morning job with plenty cursing involved!..... its running so well now I guess I had better fix the brakes :oops:
did you take a look at that bolt I highlighted ... looks like it ought to be attached too ?
