S B Rural Contracting
Went to change out the dipper end bushes this afternoon on my Kubota kx61-3 only to find they don't want to come out. Long story short I bought the machine at 700hrs and the buckets were pinned on. Towed it straight to a long job in Scotland and fitted a tilting hitch up there at the start of the job. Fitted on site so didn't bother replacing the bushes. 900 hrs later I'm back I Wales now and finally getting round to changing the bushes.
Problem is the dipper end and seals have all smushed up together into a big burr. There wasn't enough room to fit even a 0.5mm shim when I put the hitch on, and there's still no real gap. So I'm thinking it was probably battered from having side to side play with buckets pinned on.
Any way I managed to get the seals out - see photos. Took a carbide burr around the seal seat to remove the burred over steel, but I'm cautious about going too deep. Already seems like new seals might be a loose fit. It's hard to keep it a round hole.
Had a go at drifting out the bushes but neither would budge. Has anyone had a similar problem and how did you fix it? I've been told run a bead of weld around the inside of the bush so it shrinks the bush slightly as it cools/contracts.
Need the digger this week so it's all back together now but will have another look next week. Hopefully armed with a solution.
