OOPS
know what you're saying and totally agree, but that should have check/anti hose burst valves on every circuit to be compliant ..... but accidents do happen :( and would've been 100% better parked on the deck behind the truck
Maybe mine and your safer head is just thinking ‘ what’s the point in having kids stand under it when it could be safely on the floor’ 🤷‍♂️
I know it’s brand new, but I’ve seen rams split in half, metal pipework after check Valves leaking/split, and an entire grab fall off a grab wagon mid loading… (pivot pin had worn through!!) not that I’m paranoid!
another...is that a big F truck?
Gutted dropped a plate on the end of the mig gun😢
it'll rebuild .. unscrew the tip adaptor/diffuser unit and replace .... then go to the euroconnector, unscrew the nut holding the liner in, cut it right back at the torch end, pull it out, slide in a new one, trim to length, then screw in your new adapter/diffuser ... new tip and shroud, good as new (y);)
Already ordered the bits to rebuild it but needed a gun fast😉 plus it’s a 5 meter one too💪
no going back from 5m torches Mog .. you'm spoilt for life now :giggle:
I know they are intended to Al wire, but a teflon liner works really well with 0.6mm steel wire.
