Zaxis 120-1 flail head
Davidr856
Hi just wondering about setting up this digger to run a flail head. Would I be better to pipe it for a breaker or use a valve between pumps and valve block.
Tia
Ok, do you know if it has the spool on the main valve chest for it?
If not it might be best to fit a flow priority valve instead.
It will only give you single acting flow, ideal for a flail but if you wanted to run a grab or shear its no good.
Davidr856
There is a blank on top of valve chest where servo pipes can go and seems to be blanks on side of valve block on the side nearest cab not 100% sure if there for breaker or not.
Davidr856
I will look into it more. Is it just a matter of piping it up or do I need to change anything to allow flail to run and move digger together.
