Basically for a Attenuation type soakaway the design needs a surface area and a attenuation volume.
Pipe has a internal volume. The formula for the
volume of cylinder is: cylinder
volume = π * radius² * height . For a pipe use its length instead of height: pipe
volume = π * radius² * length , where radius = inner diameter/2 . The
volume of a pipe is equal to the
volume of a liquid inside (if a pipe is fully filled with it).
View attachment 20997 Then there is the surface area for the soakaway which is just the area of the stone surround. Can use whatever size you need.
