Powered pointing gun
diggerjones
diggerjones
Got lots of brick pointing to do in near future. Is there anything worth buying. What about a battery powered grease gun with a adaptered nozle
I have a manual one ... 's bloody hard work :(
Sadly not we use hawk and finger trowel push it in fast as you can with the lime then come back Trim it then churn brush it when gone waxy
Tried the skeleton gun type ones with point paving but mix was so wet and plasticised it wasn’t much cop once in the joint,
Seen some ppl using the drill powered ones on social media
diggerjones
diggerjones
Thanks. There's screw type ones on amazon for reasonable money, £50 not £350 so might try 1 of them. Money isn't an issue, just want someone to say these are the dogs
Plus it's something the unskilled labourer can do, and I can just do the trowel bit
It’s still not something for an unskilled labourer. The mix needs to be perfect.
PnuPoint is as good as I’ve used. Works well but any contamination (even mixing the third mix in the old bucket) will lead to blockages. A good plasticiser is key.
mart1602
probably just as quick with a jointer ,flat piece of tin push it straight in the joint and finish in one go .trouble with a gun it needs to be very wet to go through it and you still gotta go over it to finish it trowel will make a mess of it look on youtube for some ideas
