Peljob running fault
  • Thread starter Johnwrightpeljob
  • Start date
Johnwrightpeljob
Hi I’m after a wiring diagram for a peljob eb506 ? It has a issue running it fires up but then stops it’s not getting power to the fuel solenoid if I put my own power to it it will then stay running thanks
Id start by ruling out a faulty igniton.
Wiring diagram won't help you much, it's basic process of elimination.
Temperature switch or oil pressure switch
No holding current by the sound of it, ignition feed or fuse🤷🏼‍♂️
