W
webby36coup
Hi I have luigon 909e 2021 the main arm won’t stop raising up unless you put joystick down any ideas hydraulics fed levers any ideas thanks
Is it not within warranty still. Would have thought dealer would be first port of call at this age? Probably a stuck valve.Hi I have luigon 909e 2021 the main arm won’t stop raising up unless you put joystick down any ideas hydraulics fed levers any ideas thanks
or a sticky poppet in the joystickIs it not within warranty still. Would have thought dealer would be first port of call at this age? Probably a stuck valve.
That or solenoid on the valve block? Good chance it’s out of warrenty..or a sticky poppet in the joystick
That's poor. It's not an old machine and if the likes of Luigon want to make headway in the UK then they need to pull the stops out to inspire confidence in their machines.Hi yep out warranty been on phone to luigon tday waste time not interested will lol tomorrow at spool valve
As Druid said. Before you investigate the valves his suggestion would be the first thing to check as easier to access id thinkHi yep out warranty been on phone to luigon tday waste time not interested will lol tomorrow at spool valve
lift the boots and show 'em some WD40 then give 'em all a good wobble with the machine switched offAs Druid said. Before you investigate the valves his suggestion would be the first thing to check as easier to access id think
