JCB HYDRADIG 110W Loss of communication from upper ECU to lower Ecu and engine ecu
sepulchral
Hi, i bought a used hydradig from an auction and it moved about 10 feet off my loading dock, then all readouts on the dash went from numerical to "???".
plugged in jcb service master and i am not getting communications from the lower ecu or engine ecu.
looked (visibily) at what i could see with on the electrical swivel and i dont see anything wrong.
I will pay for any over the phone tech support. any JCB gurus? i really need some assistance please guys. thanks
Mike
Mike
have you slewed the upper structure at all, from the position it was in when you bought it ?
invest in some contact cleaner aerosols (Inhibisol electrical contact cleaner if you can find it - had carbon tetrachloride in it ) and give the commutator assembly a good dowsing, whilst rotating the upper
it's almost certainly be a 'canbus' set up so will only be maybe 5V-ish ... slightest dirt on the comm. or wipers is going to give you BIG problems, as it'll almost certainly be very low current transfer too :(
that commutator set up/assembly will need to be surgically clean, for the communication rings, aside from any main voltage rings, which'd stand some level of contamination
sepulchral
i cannot start the machine to slew anything. im kind of stuck in a bad way
sepulchral
USA, Virginia. There is no feasible way to remove the cover over the slipring electrical swivel. it hits the frame. How have others done this? surely i dont need to remove the entire swivel manifold?
THis hydradig is an effing disaster.
some pix would help :rolleyes: 'praps?
or worse still - corrosion :(
sepulchral
what is the best way to get to the "slip ring" of the machine? pull the body apart? drop the gearbox and pull it down? this machine is driving me nuts
some pix would help :rolleyes: 'praps?:unsure::unsure:
the electrical slip rings usually live on top of the hydraulic rotary coupling, so pulling it down is a non starter - that usually comes out from the top up and as a rule is fixed to the superstructure
Not something daft like a bad earth? Loose battery cable?
sepulchral
hits the frame of the digger if you try to lift it up. terrible terrible design
jd6820
jd6820
Mike
Let's start with the simple stuff first. Have you checked battery connections and the isolator switch? Then it is a case of checking power and grounds to the ECU's, have you any wiring schematics. If you get me a serial number via PM if you want and I'll get the relevant diagrams so you can trace the wiring. How are your skills with a multimeter?
Mike
so how did you look at the slip rings if you can't get the cover off?
as said previously ... some pix would be a great help in understanding the issues
sepulchral
when i lifted the slip ring cover it hit the frame, i could see that it was very clean on the inside (base) of the slip ring. could only see about 1" of the area.
CBW11CVFVH2496067
i am very good with a multimeter. I assumed there was a CAN issue at the slip rings. i would love to know where and which ecus to test. I did not find any blown fuses in the three fuse box locations that i have looked (one on the wheel body step tread, one in the cab, one in the engine bay)
I have checked leads at the starter, isolator, and batteries. even bypassed the isolator with a 12v jump box on the far end
I spoke to a technician "CHAD" at stephenson JCB in the east coast of America and he suggested i jumper across the plugs on the wires to prove or disprove the bad slip ring / can issues. I do have JCB servicemaster and from the cab fuse panel service port using USBLINK 2.0 I was able to see signals from all ecus except for the Engine ECU and the Lower ECU.
jd6820
jd6820
CBW11CVFVH2496067
You are on the right lines with a CAN issue at the slip-rings. I'd say Chad has the right idea about bypassing the slip ring for test purposes.
