Dazza537
Morning all,
I have a JCB 8018cts (2014ish), great little machine and does everything I ask of it. However its developed an issue recently. Basically when you put down the safety lever so you can run the hydraulics it gives me about 1-2 seconds movement and then stops. I have to lift the arm and lower it again to get another 1-2 seconds movement and rinse and repeat. I was hoping for an easy fix of the U shaped safety switch (magnet) under the arm but unfortunately after putting in a new one I get same problem.
The drive works all fine its just the hydraulic side of things. Any ideas?
Thanks in advance
Daz
Thanks in advance
Daz
