How tough is the rototilt r6
G
Greg5658
Hi I'm from Canada, joined up to this forum because it looks like Roto is pretty common here, I'm looking to get the rototilt r6 for my cx210d and I was wondering how tough it is. I want to get the pin on version to reduce weight and since I'll be using the rotator 90% of the time I don't really need it to be easily removed from the machine. However occasionally I need to bash through a concrete street to fix a pipe underneath, will it stand up to that? Also I do the odd demolition where I'll have a concrete footing or wall to remove. Always a man short on the crew so can't always have the backhoe hammer around to help
21t is a big size for a tiltrotator, so I don't think they'd build it weak, but I know most manufacturers are not keen on hammer work.
Someone with a lot more knowledge and experience will be along shortly, but I'm not sure you'd really notice the extra weight of a top hitch on that size machine, and if doing bulk digging the ability to remove the tilty would be handy.
Randla
Randla
Interloper
As @doobin says, a 21t tilty isn't weak. @CPS will give you specific advice on Rototilt, but Engcon's stance was quite simple - tilties and hammers don't mix. A CX 210D will easily handle the weight of a twin hitch setup and I'd say the benefits would outweigh the marginal disadvantages (build height, expense, weight). If you haven't seen it, there is a piece on configuration here.
HTH, Robert
The R6 is a tough bit of kit, I have a few working here and never had any problems.
Are you thinking of going with the pin grabber coupler or S70?
A top hitch won't add much weight or build height to a machine if that size.
You can use a hammer with the R6, although they recommend approx no more than 300 hrs per year, as I tell my customers if you want to use it to break out some rock or concrete you come across on a job that's fine.... but if you are going to break out acres of concrete take it off..
If you need any more help just ask.
G
Greg5658
Thanks for the info, I've got a full lineup of pin grabber buckets currently, I don't feel like having to completely retool. I've been thinking of getting the top quick attach in a wedge coupler. Wedge is super common out here I could pick up a spare bucket for the heavy duty work
