Hi from Cyprus.
  • Thread starter EvripidisKarseras
  • Start date
E
EvripidisKarseras
Hi,
I recently got asked to repair some wiring issues on a JCB 3CX Sitemaster 1999 model. After lots of googling around I decided to sign up.
I am mostly interested in resolving wiring issues, diagnosing faults and figuring out where to get some wiring diagrams.
This is a place where most things are imported and are subject to dodgy repairs, incorrect practices and all sorts of modifications.
Cheers,
Evros
Hi,
Cheers,
Evros
welcome to the font of all most a lot of knowledge Evros ... :ROFLMAO::ROFLMAO:
you might get lucky here @jd6820 or @Mick-the-fitter may be able to assist your quest, with a lot of folk able to chip in a contribution along the way (y)(y)
Hi,
Cheers,
Evros
Welcome Evros
Gecko
Gecko
Dodgy wiring - this'll be fun!
Hi Evros, I'm guessing your serial is in the 460000+ range?
The manuals are in the download section.
E
EvripidisKarseras
Hello to all and thanks for all this information and the welcome.
I have been fixing electrical/electronics here and there for agricultural or construction equipment but only sparingly. Also never involved in fault-finding on the actual machines, etc.
I will make good use of the electrical diagram and possibly start a thread with my findings.
Evros
E
EvripidisKarseras
Yes indeed, the serial number on that one is 0484219.
E
EvripidisKarseras
Ooops - wrong forum!
Service Manual - link should be good for 14 days
Thanks for this. It will be very useful as some findings of mine don't agree with the operator of the machine and from what I can guess.
Hi,
Cheers,
Evros
What issues do you have?
E
EvripidisKarseras
Mick, hi.
Thanks for jumping in. I will study the wiring diagram and come back to this when I am familiar with the terminology of it.
The main problem right now is electrical, related to lighting, work lights not turning on after wiring in some aftermarket LED headlights (only high/low beam). Also none of the rear light clusters appear to be getting any power, on any setting. The rear work lights work fine. Front/rear indicators also not working (I probed the wires)
The machine itself appears to have had some work done on it with many blown fuses, incorrect amperage and a dodgy relay connection (indicators).
E
EvripidisKarseras
I also forgot to mention, that when the work light switch is pressed the low-beam turns on also, but no work-lights like I said.
Can you send me a photo of the lighting switches and column stick if it still has one!
When you say work lights do you mean, top of the cab? Back and front?
E
EvripidisKarseras
Indeed, work lights -> top of the cab front and rear.
I will try and get a pic next time I am over. Maybe this afternoon even.
When you say column stick, you mean the light/indicator/wiper stalk on the right of the steering wheel correct?
Mick, hi.
typical old JakieB then:ROFLMAO:
So now I have to register on those ones too!
good luck with Maskinisten ... the translate on there can be iffy at the best of times :giggle:
