Davie is DAF`s own diagnostic.We've been having a few issues with the DAF of late, we've spent around £3k on brakes for the MOT in Feb then throttle position sensor was playing up which cost another £1.8k in diagnostic and repairs, now there's Exhaust system Malfunction warning and Engine Power Limited warnings. Was thinking of trying to find a diagnostic tool as the dealer is taking £500 off us every time we go to get an issue resolved. Wouldn't be so bad if they got it right most of the time but it's normally multiple times each problem.
Anyone any experience with DAF diagnostic tools? I think it's a DAVIE that the local DAF dealer uses but I'm thinking other systems would work?
Check error codes and clear alarms kinda thing
A basic Delphi type system will do a fair bit on them, the better the system the more cost and usually a monthly or yearly licence needed unless you go ebay knock off. The more expensive ones like Jaltest give you wiring diagrams as part of the licence.
I`ve got a Delphi but needs up dating, not sure whether to update or upgrade, but done most of what I've needed, also does car and vans, although I got a mobile guy to come when I wasn't 100% sure with an adblue fault, his system (I think he had Jaltest) went a bit deeper on the fault codes than mine, also it recoded the new adblue pump, which mine wouldn't.
The Delphi can system test some components like the adblue pump, and code some but not all parts.
With all the systems learning its description of the code can help in deciding whether its a mechanical problem, a sensor, or wiring and where to start looking first.
Are your batteries good? I've had weak batteries that can bring the exhaust warning up while starting. Is there adblue in the tank? tank gauges can stick showing some content but the tanks empty.
Check the resistance across the dosing module valve solenoid, should be around 15ohms from memory. Pull the rubber boots back off the NOX sensors, water can get in the harness and short the sensors.
